Urgent - Polyboard system error |Forum|WOOD DESIGNER
brendan kavanagh
Forum Posts: 234
May 30, 2022 - 12:16 pm
Thank you much appreciated laugh
May 30, 2022 - 11:47 am
Ok,
When you logged into Onedrive, windows itself moved your C:\Users\xxx\desktop to C:\Users\xxx\OneDrive\desktop and caused Polyboard to lose the link to those folders
Back up from software is for your setting and Post-Processor
In addition, you now have the advantage of having a backup on the cloud in case of problems with your computer
If you have another problem just like Polyboard folder libs, mat and textures again, BUT never forget to check “No take action”
Last information, make right click on folder “brendan-pb-libs” on your desktop then selecte “Always keep files on device”
files.pngImage Enlarger
like that, if you loose internet connection, Polyboard don’t loose link again
brendan kavanagh
Forum Posts: 234
May 30, 2022 - 11:13 am
Thank you Alex, you mentioned a backup do i need to do that? sorry but I’m not very good with computers if you could just explain
Thanks for you help
Caroline
May 30, 2022 - 10:47 am
I sent you an email for a zoom meeting but my English is limited.
brendan kavanagh
Forum Posts: 234
May 30, 2022 - 10:44 am
hi Alex
did that but still not working?? Can you dial in and look at computer please
May 30, 2022 - 10:30 am
Can you look if you have folder?
c:/users/brendankavanagh/desktop/brendan-pb-libs/libs
If No, make sure you don’t move libs folder to another by mistakes
Move it then give to PolyBoard the good localisation
libs.pngImage Enlarger
When the PolyBoard loses the link to this folder, it returns to the original system folders.
brendan kavanagh
Forum Posts: 234
May 30, 2022 - 10:13 am
Hi
when i signed into polyboard none of my methods are in the libraries ie the new curve i set up, cabinets methods when i go to make up a new unit
This happened before i think its something in the parameters
method is set to c/program.data/boole&partner/polyboard7
material is set to c/users/brendankavanagh/desktop/brendan-pb-libs/mat
Can you come back to me asap
Guest(s) 21
