Wrong part in manufacturing methods|Forum|WOOD DESIGNER
June 25, 2019 - 2:52 pm
Hi Paul,
I’ve sent you an email about this
Cheers,
Alexandre
June 19, 2019 - 6:17 am
Hi Paul,
I haven’t been able to run your youtube video as I get a video down message, but here are my remarks about your problem.
The Assembled parts sub method is not he same as the Structures Library.
The assembled parts sub method doesn’t allow you create the 2 railed structure that you require, you can only create complete framed panels.
This means that you cannot use a general manufacturing method to set up these rails  as it will always apply the default  Assembled Parts structure to a structured panel.
To easily get the top and bottom as you want them you must erase the Assembled Panel structure and re-apply the Materials sub method that contains the Structures Library 2 rails structure.
I know this is a bit awkward and not very coherent now that v7 contains the structure per panel type option, but for the time being this is the way the structures work. I’ll talk to the developers to see if they can change  the way this is organised.
 best regards,
June 18, 2019 - 7:18 am
list=UUoeMWz4panTZHyI2_OjGxaQ&index=2
Hi Alex this vid will explan my problem.. the file doesnt want to upload so i posted it on you tube please see the link.
June 14, 2019 - 2:34 pm
first of all I’m very sorry for the concerns you face, did you install Polyboard 7.01i or 7.01j?
…which corrects all the last bugs to our knowledge.
in the example that I attached to you after adding it to the method in your library you could see that the sub method works perfectly with the surface split
June 14, 2019 - 7:51 am
this doesnt help at all or do i miss something… i know how to split pannels and have done many difficukt ones.. the program however doesnt work..or didnt they read my inquery…really getting fed up with pb
THE MANUFACTURING METHODS DOESNT WORK.. IT ALWAYS REVERTS BACK TO THE WRONG TOPS AND SOMETIMES BOTTOM AS WELL… HOW DO I CANCEL MY UPGRADE AND GET MONET BACK.
embarassed
June 13, 2019 - 7:27 pm
To make this you must use Surface Split
please see attached cabinet as an example,
June 12, 2019 - 7:29 pm
hi,
i have sent a mail to the development team yesterday
i’ll speak to you as soon as i have news on this bug
Cheers, Alexandre
June 11, 2019 - 1:06 pm
here is 2 cabs one is corect and the other is what the comes out by default..
June 11, 2019 - 12:34 pm
hi,
can you send us your cabinet?
All the best, Alexandre
June 11, 2019 - 10:22 am
After setting up my methods and material panel structure… when addding a new cab it always puts the wrong top on the cab… see pics. it works correctthe first time.. but when making a new cab it always use the default in assembled part. i then have to delete the assenmbly and redo the top again.. the rest works perfecrly.problem-i-think.JPGImage Enlarger
correct-top.JPGImage Enlarger
pol1-wrong-top.JPGImage Enlarger
p1.JPGImage Enlarger
crycry
opening it again just now it gave me the wrong top and bottom… where can i disable assembled part? can i
Guest(s) 33
Conor Devoy: 173
Jan Peter Oelen
ANDI MÖÖBEL - Tarmo
Topics: 2964
Members: 562
