XCS export settings for drills|Forum|WOOD DESIGNER
I assume it’s the mobile shelves?
In Xilog Plus PP, 2 superposed drilling as automatically merge to thought drilling Type “L”
If that’s the case you can to force “P” flat drilling instead of “L”
by creating specifique Tool and associate it to drilling (the diameters is automatic, just need to said drilling is type “P”)
Please see attached video
This can be applied to any fittings with through drilling you wish to force as flat drill bits.
OfflineI exported unit which has both 5mm and 3mm drillings. Both load into Maestro fine and nest without problems until I come to save the file. After much digging I have found that for the 3mm drilling CSV is defining that the bit is tapered which causes the problem. It needs to define the bit as being Plate. Where can I modify this and where in the CSV is this setting defined so I can check the output? Thanks
