Simple home stairs|Forum|WOOD DESIGNER
Simple home stairs
Derek Lamb
Forum Posts: 7
July 13, 2023 - 1:33 am
Thank you, Alex
Looks great.
July 1, 2023 - 7:08 pm
I’ve just come to see your message !
All my apologies for this issue please find the PDF files attached
wishing you a good manufacturing, Alex
Derek Lamb
Forum Posts: 7
July 1, 2023 - 1:11 am
Thank you Alex
I am having trouble with the files sent. The pdf reads 0kb, no content, unable to open. How do I get a cutting list?
Thanks again.
June 30, 2023 - 10:19 am
Please find you files attached,
Kind regards, Alex
  • sp_PlupMedia ZIP_StairCJune23.zip(262 KB)
Derek Lamb
Forum Posts: 7
June 30, 2023 - 8:21 am
My apologies, Alex. The wrong plan  was uploaded. My plan is to use a straight handrails and stringers, for simplicity. Please find attached correct plan. I have corrected penetrations to 20mm. If this is correct for newel posts of 90mm, then please check I have not made any other errors. I will check the correct file is uploaded after posting.
Thank you.
June 29, 2023 - 9:03 am
In the attached file, I have made a slight adjustment to the market penetration, but there are no other concerns,
If you agree, I will send you the documents.
Kind regards, Alex
Derek Lamb
Forum Posts: 7
June 29, 2023 - 2:18 am
Thanks for that correction. I have corrected the penetration values for steps. Does this penetration value (20mm) hold for stringer to newel posts? I have changed it to this value on the plan.
June 15, 2023 - 1:33 pm
A quick note: the staircase you upload already has a 30mm penetration between the step and the stringboard. 20/15mm is sufficient and easy to mill and assemble.
links.pngImage Enlarger
Derek Lamb
Forum Posts: 7
June 15, 2023 - 12:11 pm
Thank, Alex
I think I’ll stick to simple, straight for my first stairway. I think I’ve made the changes you suggested. I made changes to step penetration to newel posts, as it may allow easier assembly, sliding in. Depth could be altered to match stringer penetration.
Would this plan work?
Cheers,
Derek
June 12, 2023 - 8:03 am
This may also depend on your installation solution. I think that stringers and curved handrails are more comfortable, but there is also the alternative of using straight per parts and subtly softening them.
-In files joint, I can’t see the correction for penetration
-In curved mode, handrail have different dimension from others ( Right handrail 2 – 62*42 instead of 42*62)
as it is wider than the stringboard, it will have to be offset by half a thickness to bring it back into line with the stringboard.
Guest(s) 37
