Hi guys, it looks like Saulius started 2 conversations on the forum about this. This topic is now closed. Please continue the discussion here: https://wooddesigner.org/forum…..-design-1/
I have some problems with central beam curving(adding picture how i want it to be). In drawing you can see that central beam is straight and i need it to curve on the corners.
Other question would be, how to put CAD drawing into stair designer if its possible.
I need dxf file. Will i’ll be able to put it again into stair designer?
