Building a stairs between two walls and I would like to hide the strinboards underneath the steps. Is it possible to get this kinf of strinboards out of the program?
– Support for flight number 2 in tight 180 deg turn is taken from floor with poles underneath on each step. wall thikness on 180 deg turn is 92 mm.
– All steps on flight number 3 goes above middle wall. Newel posts are attached to side of wall.
