Winder Issues|Forum|WOOD DESIGNER
Winder Issues
July 4, 2021 - 8:03 am
Hi Kevin,
No it is not
July 3, 2021 - 2:37 pm
Thanks again Michel,
Is the strength compromised at all if it is a closed stringer?
July 3, 2021 - 1:29 pm
Hi Kevin
Here a picture of some steps I made . You can clearly see these are made out of 2 pieces of wood. This is better then only 1 piece as this is more stable.
steps.pngImage Enlarger
July 3, 2021 - 11:22 am
Thanks for the confirmation Michel, Phew !!!!!!
July 3, 2021 - 10:42 am
Hi Kevin,
You can make a wooden panel by glueing several parts together and cut the steps out of it. For winder steps, panels are glued so that you can cut 2 steps out of it.
Below is a panel of 600/1300 containing 2 steps.
panel.pngImage Enlarger
Before glueing the panel make sure the wooden parts are processed through a wood planer and squared up correctly as this defines the quality of your panel. Make also sure that the grain is alternating to make the panel more stable and avoid warp.
grain.pngImage Enlarger
Regular wood glue will do the job
July 2, 2021 - 12:53 pm
Me again.
Being new to manufacturing stairs it seems that I have more questions regarding the build rather than the software so please forgive me.
Similar to my post regarding Stringers and widths of material, I have a client that wants 32mm pine treads which creates a problem with the winder treads as I cannot get that material wide enough to make complete winders. Can you join winders to make the width, and if so what is the method for doing this bearing the load they will have to regularly take.
Any advice would be really helpful as I cannot find any information regarding this on the net.
Many Thanksembarassed
Guest(s) 31
2 Guest(s)
Conor Devoy: 173
Jan Peter Oelen
ANDI MÖÖBEL - Tarmo
Topics: 2964
Members: 562
