Help with project |Forum|WOOD DESIGNER
In your Stair you use “Joint” to make curve but that can’t work with “landing”
Please see this with to show you how you can edit to work
Hope that helpful, Alex
Sorry to answer so late, I’m checking with my colleague Michel and will keep you informed, but the double output is not available from the software
OfflineDuayne Naugle said
Duayne Naugle said
Duayne Naugle said
need some help , i have a stairway to build , it is flared out from bottom to top on both sides with volutes on the bottom , there is a landing at the top of the first flight then turns 90 degrees 2 steps , the left and right side into an oval rail that is 39′ in length , i am able to get the stairs pretty close to what i want , but the landing does not work with the flare , i will attach a photo of the job for a better understanding
in the picture below , it shows a bowed set of stairs up 14 risers , then turns to both sides , left and right for another 3 risers at the top floor , there is an oval shape that the rail should run continuous , with only 2 volutes at the bottom of the stairs , tried to start with a straight flight and set a join on both sides to get the curve i want but as soon as i add a landing the join disappears , the landing can only go one way , left or right but not both ways
Offlineneed some help , i have a stairway to build , it is flared out from bottom to top on both sides with volutes on the bottom , there is a landing at the top of the first flight then turns 90 degrees 2 steps , the left and right side into an oval rail that is 39′ in length , i am able to get the stairs pretty close to what i want , but the landing does not work with the flare , i will attach a photo of the job for a better understanding
