Newel Post and Tred Line Radius|Forum|WOOD DESIGNER
Unless I’m mistaken, the tread line is similar to that of the SD6,
(EDIT: image link no longer active)
The difference is now from SD7 you can be edit from both sides, and bisectrix
Hasse Svensson
Forum Posts: 63
February 18, 2014
OfflineIn that attachments you post you have a wide of the flight on 1000 mm, you have put tredline 100 mm from the right side. You get radius of 900 mm.
In Stairdesigner 6 you cold select a radius of for ex 350 mm anywhere you put the tredline.
In SD7 you only get the radius of where you put the tredline. In this case I put the tredline 400 mm from right side, I have 600 mm from left side to tredline, and I get 600 mm radius.
Guest(s) 38
© Simple:Press —
