positioning above nosing- winder stringer|Forum|WOOD DESIGNER
Forum Posts: 1029
April 21, 2024 - 4:43 am
Hi Yohaan,
Here is a video explaining how to solve this by editing the stringboard. This is to be done at the very end of the design as every change to the stair might trigger a recalculation and delete the editing of the stringboard.
Yohaan Chandra
Forum Posts: 19
February 27, 2024
April 20, 2024 - 10:48 pm
Michel said
Hi Yohaan,
Alex asked you to add your stairfile to the post. We always need it to check the stair design itself in order to provide you with an answer.
As you know, every situation is different and might be challenging when designing a staircase. Based on your question, I could deduce that you mostly rely on the 2D view when you design.
You always need to check your 3D visual in solid and wireframe in order to spot some possible anomalies.
We will further investigate your request when we have received your stairfile.
hi michel, here is the stair file
Duayne Naugle
Forum Posts: 130
March 1, 2015
April 20, 2024 - 7:04 pm
did you use paper templates printed with a large format printer , if so , it could be as simple as you  not using a wide enough page and that section was just not printed
Forum Posts: 1029
April 20, 2024 - 9:54 am
Hi Yohaan,
Yohaan Chandra
Forum Posts: 19
February 27, 2024
April 20, 2024 - 1:44 am
 we joined our stairs when we installed and had to make modifications on site. this shouldnt happen as the program should be aware that as finished staircase it will have a gap showing the underside of the stairs. additionally we are lucky as we are doing double stringers for glass balustrading, so the double stringer will cover the gap. is there any possible way to maintain the offset on these stringers?
Alex said
Can you joined your stair?
Kind regards , Alex
Forum Posts: 1917
April 19, 2024 - 7:32 am
Kind regards , Alex
Yohaan Chandra
Forum Posts: 19
February 27, 2024
April 19, 2024 - 5:49 am
is there a way to maintain the positioning above nosing offset? i have attached an example stringer of a project i did and when installing ran into the issue that the risers were much too close to the stringer edge and when connected to the lower stringer it leaves the riser underneath exposed, is there a way to get around the issue or to maintain the offset distance even on a winder stringer?
left stringer 2:Screenshot-2024-04-19-144403.pngImage Enlarger
Screenshot-2024-04-19-154241.pngImage Enlarger
Most Users Ever Online: 365
Guest(s) 58
brendan kavanagh: 153
Conor Devoy: 146
Zaheer Abbas: 119
Blake Simpson: 104
Robert Coxhead: 74
Patrick Maylor: 74
Olga Safari
Greg Allen
Maximo Vinet
ben levene
roni ben ami
Kateryna Druzenko
Joseph El Hajj Moussa
razvan george tomas
Dennis Nwachukwu
Richard Maursky
Topics: 2325
Members: 349
