Hi again,
The ref is the wall or stair well dimensions.
So if there's an outside wall and the stair turns left the outer wall is on the right.
cheers,
December 22, 2014
Ness said
Hi again,Sorry, here's the new stair model.
In this case the last step can not be forwards of the first flight outer string.
hi again
why is the reference setting; "right"??
i just wonder. the stair turn left!
Ness said
Hello Morgens,Here is a model for you stair:
note that the first step can not be behind the outer face of the second string, so you have to adjust the length of the first flight accordingly
This means that the length of the first flight must be equal or greater that the width of the second:
hi ness
hi ness
it should end up with 1/4-turn at the top off stair
mogens hansen
December 22, 2014
hi ness
hi ness
Hello Morgens,
December 22, 2014
hi
i have tried to make a staircase in stairdesigner
it's a narrow staircase, see attached cad-file.
stairdesigner can't accept the measurement
total Rise is 2565 mm and the length can be between 2500-2700 mm. The width is 695 mm and can't be changed.
can you help?
mvh
Mogens
