Problem with winders|Forum|WOOD DESIGNER
Duayne Naugle
Forum Posts: 130
November 19, 2021 - 3:11 am
Alex said
please find your files attached
All the best, Alexandre
I was looking for advice and figured it out myself  , i do have the ability to produce the documents myself , thanks anyway!
November 3, 2021 - 11:59 am
  • sp_PlupMedia rockcliff-3-1-3D-inch-frac.zip(472 KB)
November 3, 2021 - 10:51 am
Hi Duayne,
I requested Alex to send you the documents today
November 2, 2021 - 7:16 am
Hi Duayne
I will revert to you this evening as I am currently not available.
Duayne Naugle
Forum Posts: 130
October 29, 2021 - 5:02 pm
I tried multiple ways to achieve this , in the end i did use 3 landings to make the 3 step winder ,
i was able to make a change in the length of the  right side of the opening to 7′-5 13/16″ which gave me a  run on each tread to 10″  i also dropped the number of treads to 9
 this is working out better
October 29, 2021 - 2:49 pm
Hi Duayne,
As stairdesigner is calculating in the European way we are not able to define the thread width as it gest calculated over the qty of steps and distance.
Also, the 3 steps winder is not a standard in this calculation. To achieve a 3 step winder the best way is to build up the flight with landing and edit the shape.
I have added a version that you can use to finish your project.
The only way to affect the tread width is to add or remove a step in the flight or change the length of the flight.
Duayne Naugle
Forum Posts: 130
October 28, 2021 - 12:18 am
I have a set of stairs that i am trying to make work to a specific length , Here in Canada we are only allowed 3 winders in a flight of stairs , if i make adjustments to the winders , it automatically changes the straight run  per tread to over 11″ , i need to make the straight run with a tread width of 10″  ,
if i change the straight flight so the treads = 10″ it messes up the winders .  the problem seems to be the winding coefficient , the controls for them don’t seem to have any effect on the outcome , the walking line here in Canada is 12″ from the handrails , i can’t find a way to make that happen
how can i make this work .
 included is my file
Guest(s) 41
Conor Devoy: 173
Jan Peter Oelen
ANDI MÖÖBEL - Tarmo
Topics: 2964
Members: 562
