Question regarding Local and Distant settings|Forum|WOOD DESIGNER
Forum Posts: 2128
July 20, 2023 - 12:29 pm
For missing parts start by change option “Tooled parts” to “All parts”
Tooled parts only export no rectangular parts,
parts.pngImage Enlarger
For cleaning you can also add value into “Groove lengthening” option, and may be interesting to active “Group Step and Riser Notches”
If using the same tool
Can you upload your stair to look?
Cheers,
Anatoliy Leonenko
Forum Posts: 2
July 20, 2023 - 8:59 am
Good, morning. Thank you, it works.
When I made the export of the stairs to the TpaCad format, it didn’t export all the parts, some risers are missing.
Also on the stringboard it does not clean the space for shelves (emptying), and for risers.
Screenshot-2023-07-20-085920.jpgImage Enlarger
Forum Posts: 2128
July 20, 2023 - 7:54 am
You always able to compresse it before upload,
Right-click on the file or folder.
Move your cursor over the “Send to” option. This will open a new submenu. Select “Compressed (zipped) folder”.
Zip.pngImage Enlarger
First solution in mind is ti fixe steps using fonction “Straight step”
Straight-Step.pngImage Enlarger
the sliders will have an effect on the overall distance, and will modify the distance outside without modifying the distance at the level of the tread line.
ditance.pngImage Enlarger
Hope that’s helpful
Anatoliy Leonenko
Forum Posts: 2
July 19, 2023 - 6:13 pm
Good afternoon.
Is it possible to get straight steps like in pic.2 with the joints like in the pic1?
180323.jpgImage Enlarger
P.S. Could you please, increase the uploading file size, Now is 2023, not 1999. cool
Currently Online: Nadeem Lotia, Isaac
Guest(s) 58
Timothy Bennett
Members: 536
