SD7 Manual|Forum|WOOD DESIGNER
SD7 Manual
April 3, 2019 - 6:45 am
Hi Hasse,
SD7 can fully edit the shape of stringers but currently does not allow to overshoot his boundaries. This means extending the stringer 50mm below the floor is currently not possible. You will have to use a cad program to adjust the stringer.
There is a way to do it in SD7 but the cad work is faster. You can start the stair with a landing and use a very short length of 0.01.
After this, you add your flights and add 50 mm on your total height. What you can do now is change the height of the first step which is a landing. You set it on 50mm and removed the riser and set the landing on 100% transparency. This will shape your stringer with the overshoot. You can still modeling the stringer to become the shape you need.
About the step-shaping SD7 can do this. There are 2 ways of doing it. You can go to the step-view and select the step you need. Double click on it and you are in the edit mode. You can now model your step. The second way is to right click on the step so that you can select the step-shaping feature. This will launch a window that allows you to add predefined steps and also select on specific steps. I added some pictures and the stair with the shaped stringer. This feature can always be accessed with a right click on the worksheet in stair-view.
Hasse Svensson
Forum Posts: 61
March 31, 2019 - 11:15 am
Is there any full manual on SD7 to download?
(I have an old manual of SD6)
Right now I want to modyfy stringboards start to start 50 mm under floor.
Then I want  to get different shapes of startstep.
Best Regards from Hasse Svensson Sweden
Guest(s) 94
brendan kavanagh: 212
Zaheer Abbas: 158
Tom Jackson: 113
Aurelian Draghici
Rory Parker
Harish Kiran Jetti
Gerard McDonagh
Livvy Kendrick
Esteban Raisiere
Monica macias garcia
arno.s
JP123
Topics: 2777
Members: 486
