Stair project and drawings|Forum|WOOD DESIGNER
Hi Maris,
Here are the documents. Stairfile is also in it but I made it with the latest sd7 version 7.10F. If you cannot open it please download the latest version from the website to open it .
Have a nice bild and send some pictures 🙂
Hi Maris
I can only reply this evening when I am back. It will be around 7 pm today
Ok, everything looks grate apart from
1. Stringboard #1 on top flight. It needs to be Cut string from the visible side. under steps for design and how it look reasons. I can accept offset for visible Cut strings if the reason is better joins wits posts.
2. Bottom post. Can we integrate it deeper in step number 2 to avoid visible gap between steps number 2 riser and post. The riser can be cut in to post as well.
Cheers
Maris
I made some changes as follows
penetration of the parts reduced to 15 mm
tenons on stringers and cut stringers in connection with the newels
Riser penetration in the step-nose side and going behind the back of the steps.
Stringer on the first flight 20mm overpass on the first step
added a landing step
Made cuts to make separated stringers between flights and landing.
My question is what kind of handrail are you going to use as there is not a lot of room between the flights to pass by
Hi Maris
I am currently checking your planota 3 stair . I will revert shortly
