stairfile order|Page 2|Forum|WOOD DESIGNER
Hi Lee,
Thanks for buying a StairFile.
I’d tweaked you stair so that it’ll be easier to setup and build on your CNC.
Here’s a quick list of the main points I’ve adjusted :
– setup a materials and methods library
– reduced the step and riser housing to 12mm
– extended strings beyond the first and last steps.
– adjusted winders and optimised string widths and shapes.
This should work fine on your CNC. When you get the machine, we’ll have to set up the correct layer names and Vcarve import templates and you’ll be able to just load the dxf files into Vcarve and run the machine without any problem.
EDIT: I just checked our records and I see you’ve already got the CNC from Radecal. So let’s continue with the design, once you’re happy with it we’ll move straight on to sorting you out with the right output for the machine.
I attach the file for you to review.
