Lost password?
mpr number in cutting list
Forum Posts: 1204
March 27, 2023 - 11:33 am
You can change parts orientation from PP,
PP.pngImage Enlarger
part.pngImage Enlarger
Conventional =  Height on Y
Rotation = Height on X
Hori max = longest length (height or widht) on X
Girts Martinsons
Forum Posts: 51
May 21, 2021
March 27, 2023 - 10:54 am
My CNC guy has an challange.
When he is placing taking the MPR file - it makes to place the detail across the CNC area. (the detail width is bigger than CNC area)
As I understand then I have placed the texture for details - and Polyboard is making the detail MPR file reffering to detail height(length), the programm is not rotating the detail.
What would be solution - is it possible to find in programm - or the CNC guy has to find the way how to rotate detail + axis for CNC?
Please see the attached files
Forum Posts: 1204
March 13, 2023 - 2:39 pm
Yes this bug is under correction
drilling.pngImage Enlarger
I send you mail
Girts Martinsons
Forum Posts: 51
May 21, 2021
March 13, 2023 - 1:29 pm
Girts Martinsons
Forum Posts: 51
May 21, 2021
March 13, 2023 - 1:28 pm
I have a problem in PDF, there is detail with a lot of drills, but it shows me this small detail.
Is that a Polyboard problem?
https://failiem.lv/u/r5yf4ty6s - here you can download the project and files.
Thanks.
BR,
Girts.
Forum Posts: 1204
November 9, 2022 - 12:46 pm
There are 2 different parts.
Cutting list options for OptiCut or ASCII
From menu Cutting list > Cutting list options
Net dimensions with edges deduced from panels
Overall dimensions with final parts dimensions
Post-Pro option
This makes it possible to cut and then machine before or after the edge banding,
Hope that's helpful, Alex
Girts Martinsons
Forum Posts: 51
May 21, 2021
November 9, 2022 - 8:08 am
I have a problem with detail dimensions in MPR file.
In cabinet there are detail dimensions - Height 282, Width - 504 mm
But un MPR file the width is different - 502.4 mm (as it seems it is taking off edgeband thickness)
What should I change in setup, to get correct dimensions?
Please see attached photos: Capture-1.PNGImage Enlarger
WhatsApp-Image-2022-11-09-at-9.53.11-AM.jpegImage Enlarger
Forum Posts: 1204
October 4, 2022 - 6:53 pm
from menu cutting list
1 In format ASCII add "Tooling file first and second face"
2 Synchronised with your current PostPro
3 Serial to No to have file name instead numbers
4 Start OptiCut to No
cuttinglist.pngImage Enlarger
Now ASCII export columns with this information
ASCII.gifImage Enlarger
Hope that's helpful, Alexandre
Girts Martinsons
Girts Martinsons
Forum Posts: 51
May 21, 2021
October 4, 2022 - 11:47 am
Alex said
Can you tell me about your output process?
after PolyBoard?
If I look at your files you don't have OptiCut it's true
But with which software do you make the cutting plan and which format?
At the moment there are two cutting plan programms, - I`m exporting txt file in excel and then i`m importing in in programm.
I`m interested to work with two cutting plan programs - sketchcut or optiplannin (or something like that)
At the moment I need to understand where i can get out the necessary file number for each detail.
Is it through post processor export ?  project name+ detail name + material + edgands + file number?
BR,
Girts.
Forum Posts: 1204
October 4, 2022 - 7:57 am
after PolyBoard?
Girts Martinsons
Forum Posts: 51
May 21, 2021
October 3, 2022 - 12:08 pm
Tell me please how to properly set parameters to see mpr file number in cuttinglist linked to detail?
I choosed in cutting list options that I need in cutting list export also tooling file F1 and F2. but it is not appearing when I`m exporting the cutting list.
But there are fittings that are made in cabinet.
I can export mpr file, but i don`t see the file number opposit the detail.
What should I do to make it proper way?
Thanks.
BR,
Currently Online: Stefan, Daniel Petrov, waqar abbas, pinku ch, cha thim, David Grout
terry: 253
mark nichols: 157
Tom Cleaver: 144
Kerf Works: 143
Duayne Naugle: 124
brendan kavanagh: 112
jimbouk: 105
Syslab Corp: 103
Stu Robertson: 102
Mukesh Puthran
Gowri karthika
Gowri karthika
Clint Johnson
samuel Akapo
samuel Akapo
Marko Pedosk
mus til
kadri kadri
Vicky Hunter
Topics: 1827
Members: 150891
Administrators: Ness, Stefan, Michel, Carole, Alex, admin, Laly, ipatrick, Fatima, Crystal, Jem Turner, Darren
