Not all .pgmx are created, PP Maestro/SCM|Page 2|Forum|WOOD DESIGNER
Hi Guys.
Have update on my previous post.
Anyway – had to update Maestro to newer version. After update, I noticed that XConverter didnt work. Figured out that they had changed folders where Maestro is stored, and if i copied tooling folder to folder where Xconverter is, then it was working fine, kind of.
It works partly… I have project with different materials. When Post-processing using SuperPP or just normal PP different folders are created for each material as supposed to. But when it comes to creating .pgmx it does it for one type of material, and then stops creating them on other. If Post-Processed whole project then can even end up with half .pgmx created and second half are missing .pgmx files! .xxl files are created every time.
So I`m ending up with missing pgmx programs(a lot of them), that i need for machining. Was trying all around but without lack.
Please let me know how can I fix that, as all projects at standby as cant create programs.
Sandis
P.s – wild guess – could it be something with folder locations? As previously you found out that tooling file name was too long, and needed to reduce it shorter for it to work.
