Solution for XILOG MAESTRO nesting "piece naming"|Forum|WOOD DESIGNER
Forum Posts: 949
May 23, 2019 - 10:43 am
Hi there,
Can you use our contact form, link below, to introduce yourself to our team.
We can then have a chat about how to work together if you’re interested.
May 22, 2019 - 12:08 am
sorry wrong attachment cant edit the post.
here is the right one
May 21, 2019 - 11:55 pm
Thank you, premium sounds good 🙂
I wrote opticut postprocessor for new SCM saws that runs new version of “wincut” now called mestro cut. Its very diferent uses kind of xml format, header , folders, label data, LST files are nov XMIX files and 001,002 files are now 001.xprg 002.xprg and so on on but the cutting sequence is simmilar.
here is the tested post developers can implement it in to new verrsion of opticut.
Looks like developers are too bussy  🙂
code is probably not showing right so please download it from attachment
https://pastebin.com/R3SUYg9p
<! Paramčtres d'export !>
<file=xPrg\*_???.XPrg|8.3>
<varSep=,|subst=\,>
<varGrpStrip=1|ctrl|optSpec=7>	<! ATTENTION: ŕ placer avant 'ctrlMaxCut' !>
<! Contrôles de l'optimisation !>
<ctrlMaxCut=100|l=tcEsrp>		<! ATTENTION: ŕ synchroniser avec  !>
<ctrlMaxCutDepth=4>
<ctrlMaxCutMapQty=9999>
			<! Un fichier par plan de coupe !>
<varUnit=md3z>					<! millimčtres avec 6 décimales !>
<! En-tęte du fichier !>
<<HeaderDescrizione="<mat:ref|fmt=50>"Spessore=""Date="12/01/17"Lunghezza=""Larghezza=""SpessoreLama="4.400"/>
<<MaterialTipologia="TYPE"Codice="MAT"/>
<	<! ATTENTION: ŕ synchroniser avec  !>
<tab=2><<CutT="P"Dim=""Rip="1"ID="1"EtiID=""/>
<enumItem|l=tcEsrp>						<! ATTENTION: ŕ synchroniser avec  !>
	<tab=2><<CutT=
	<! Code de coupe !>
	<CutLine=t><<CutT="R
	<CutLine=tc><code|1=P|2=Y|3=X|4=U|5=V|optSpec=8>"
	<CutLine=Esrp><<CutT="F"Dim="0.000"Rip="0"ID=""EtiID=""/>
	<! Cote et répetition !>
	<CutLine=t>Dim=""Rip="1"ID=""EtiID=""/>
	<CutLine=c>Dim=""Rip=""ID=""EtiID="
	<CutLine=Cp>(<i|perCutMap|optSpec=12>)
	<CutLine=c>"/>
	<! Description des rainures (non utilisé) !>
<! Liste des pičces !>
<varUnit=md2z>					<! millimčtres avec 2 décimales !>
<tab=2><<EtichettaId=""Codice="<custom=1>"Lunghezza=""Larghezza=""Richiesti="<q|total>"CodiceBordo1=""CodiceBordo2=""CodiceBordo3=""CodiceBordo4=""Job=""Campo1=""Campo2="<custom=1>"Campo3="<custom=2>"Campo4="<custom=3>"Campo5="<custom=4>"Campo6="<custom=5>"Campo7="<custom=6>"Campo8="<custom=7>"Campo9="<custom=8>"Campo10="<custom=9>"Campo11="<custom=10>"Campo12="<custom=11>"Campo13="<custom=12>"Campo14="<custom=13>"Campo15="<custom=14>"Campo16="<custom=15>"/>
<! Fichier liste des plans de coupe !>
<resetFile=..\xMix\*_???.XMix|start=1>
<varSep=>
< <<HeaderDescrizione="<title|fmt=50>"Import=""Date="12/01/17"/> <
<Header=nbr> < < <newFile|%=99> <tab=2><<RigaMixFile=".<fileName|main|path:rel=..\.>"Rep=""Pacco="1"CambioMateriale="0"/> < <
April 28, 2019 - 7:45 am
This is very useful information thank-you very much for posting.
I’m sorry not to have replied sooner.
If you would like to post more and interact with our Premium Support subsribers, we can set you up as a Premium subscriber for free.
We could also offer to pay for relevant and helpful posts.
If this interests you please use our contact form and write to Stefan.
Thanks again for your post and I hope that we will be talking again soon.
March 22, 2019 - 2:22 am
Hi I read your problems at polyboard forum at
https://wooddesigner.org/forum…..am-naming/
I made you solution and I can help with anything 🙂
I am cad cam specialist for SCM machines, I like to help people.
Basics:
I wrote a report file that has .BAT extention , it will be generatet with polyboard PP export with files. then you click on it and “WUALA” you have ready made csv , to import in to maestro for nesting with all corect file naming and so on.
FOLLOW these steps:
STEP1
step1-1.pngImage Enlarger
open formating of PP Report and write this in to it EXACTLY(also in attachment) line by line with option. IF you see or anything in this <> pull it from left side menu:
@ECHO OFF &SETLOCAL enableDelayedExpansion &SET "filename=
<File Name>
"&echo [PARTPROGRAMNAME]=!filename:~0,-4!_output.pgmx;[CODE]=
 <Cabinet>
 _
 <Piece References>
 ;[MATERIAL]=all;[QUANTITY]=
 <quantity>
 ;[EXTRAQUANTITY]=0)>>CSV.csv
STEP2:
Then klik ok and you shoul see this line
step2-1.pngImage Enlarger
name the report file name how you want but (best is “GENERATE_CSV.BAT) it has to have .BAT estention so you can easy click and run it.
STEP3:
Generate pro pp files you should see these preview or report file like this
step3-1.pngImage Enlarger
then yor files are generated like this
step4-1.pngImage Enlarger
last step double klik on .bat file and it will generate .csv file ready for your maestro. you should see this (extra csv file)
step5-1.pngImage Enlarger
here is the preview of csv file generated
CSV-preview-1.pngImage Enlarger
i added only nesesearly fields if you need more like with and hight deph let me know . but it should read automaticaly.
sorry for my english
Cheers
Scm XILOG CAD-CAM specialist
Most Users Ever Online: 704
Guest(s) 47
brendan kavanagh: 205
Conor Devoy: 158
Zaheer Abbas: 154
Patrick Maylor: 108
Tom Jackson: 106
Maciej Jaworski
Eleanor Maple
Filip Godu
Erik Rickert
Brandon Januarie
David Triller
Nathan Bruton
Michael Okyere
Timo Pitkänen
Topics: 2725
Members: 470
