Xxl-pgnx|Forum|WOOD DESIGNER
Extra information to be converted make sur your tools number are well completed into PP setup, this point are controlled by Xconverter
For example milling tool E101 become 1001 for pp setup
All the best, Alexandre
To send files ONLY please use our contact form.
We will not answer technical questions by mail
Online did you select the patch for the Xconverter.exe files?
As I don’t have it, I can’t send a suitable screenshot.
Alex said
Hi,Can you upload cabinet used and Post-Processor setting as *.Zip?
The files are not converted from xxl to pgmx or exported at all?
1* Can you process an update by downloading installpolyboard.exe from this page (more information here) , then process news export
2* May update have reset option due to bug correction, Like attached Screenshot, please Set option “File Name format” “Without Accent ans special characters” , then process news export.
Hello Alex,
i have manage some to work but machine parameter is Null after x converter, i have to re enter machine parameter in my maestro to work My machine Work with parameter (DC)
can i have ur mail id i cant up lode post processor report.
Hello
when I convert xxl file to PGMX all parts are not converting only vertical and dividers parts which only with drilling programs are converting .
The problem is parts with groves and routing job are not converting.
it was fine in my PP.7.05 after converting 7.07 it creat problems.
can anyone Help me
