Hettich Actro YOU Avantech drawers and rules|Page 3|Forum|WOOD DESIGNER
January 3, 2022 - 8:13 am
Thanks for supports.
Could you please tell me How can I create two drawers connected to one facade – for example I want to create 250mm cargo with Hettich Atira drawers..
Thanks.
250mm-cargo-1-facade-2-drawers-connected-to-facade.PNGImage Enlarger
Forum Posts: 2128
December 16, 2021 - 10:29 am
May be with Slack in depth setting
sid.pngImage Enlarger
December 16, 2021 - 9:59 am
Tell me please,
How can I create built in drawers in innercasing to they are recessed from front – 80mm?
Thinternal-drawers-deeper..PNGImage Enlarger
anks.
Forum Posts: 2128
December 13, 2021 - 12:38 pm
Please see this first video to restore the method and sub-methods
and how to edit it to AvanTech Height 101
The H77 update that had the 101mm height settings, attached
another video on how to simulate the Built in drawer front
Hope this helpful,
Best wish, Alexandre
December 12, 2021 - 5:43 pm
Thank you for rules – one more time.
I Want to understand – how I can create internal drawers – which are located behind the doors?
And could you please tell – how I can create a structure for drawer frontage to imitate internal drawer aluminium front?
How I should prepare that one correctly?
December 10, 2021 - 6:02 pm
Thank you very much,
Could you help me – how I have to stock these parameters correct in to libraries correctly?
I`m confused  little bit.
BR,
Girts.
Forum Posts: 2128
December 10, 2021 - 3:02 pm
Please you can find Upload Models with the complete configuration of Hettich AvanTech you height 77,
Manufactured+Sub-equipment+Sub-drawers with “strength furniture”.
You can restore, test, and duplicate to make all other heights.
and check “strength furniture” drilling position I didn’t find
be careful that the other drawers have a recess value between the drawers Top at the back of the drawers -21 and not -26 as 77 (under drawer sub-methods)
Good luck, Alexandre
December 10, 2021 - 11:41 am
Hi, should be
Forum Posts: 2128
December 10, 2021 - 11:39 am
For the quick follow up please do it on the forum
just right click on the file (or files) to “send to” “compress folder”
to make it a zip file without constraint
December 10, 2021 - 11:24 am
Forum says that file is too huge. 🙁
Maybe I can send you directly by email?
Thanks.
Guest(s) 58
brendan kavanagh: 227
Emmanuel Sacco: 196
Carl O'Meara
polyjohn
Maxime Marengere
everslyjoinery
Topics: 2906
Members: 540
