Michal from Poitiers, France |Forum|WOOD DESIGNER
May 28, 2015 - 5:20 pm
Thanks Michal, I think he has already asked me for a quote.
28
May 28, 2015 - 5:00 am
The company that cuts the parts is named Agibox (name of the boss is Sylvain Cotte). In order to acquire Polyboard, he filled an application to have some money from the region. In fact he can pretend to have 10 % subsidiary help of the total amount. I now work there for two weeks, I was interested of how they work with their CN…
Cheers,
Michal
May 27, 2015 - 7:45 am
Hi Michal,
Thanks for posting your photos, the project looks great!
Can you tell me the name of the company that cut the parts?
Looking forwards to doing another project with you this way.
Now that we have ironed out the nesting parameters it should work even better.
mark nichols
Forum Posts: 160
May 18, 2014
May 26, 2015 - 4:00 pm
Looks Great
Glad to be of help
Mark
25
May 25, 2015 - 4:06 pm
Nice work, Michal!  Love the look of it!
Christopher
24
May 24, 2015 - 1:52 pm
I’m back with the project finished. The client is very satisfied.
The production process worked nicely. I’ve set sub-methods in Polyboard for hinges, sliders and drawers, grooves for back panels, holes for mobile shelves and edging… Ness prepared a nesting (with Optinest I suppose) in panels as the CN company works that way (in attached picture you can see the cut off panel)  The cut was extremely precise and I’ve certainly saved lots of time working this way. As the CN machine was not able to make grooves in panel edge, I’ve made all assembly with my Domino, which is very fast as I don’t need to measure. I could use dowels and cams but that suppose machining each individual part separetely… and the cost would be much higher I suppose.
I made a demonstration for the boss of the Cn company and he was very impressed by the possibilities of Polyboard, they plan to buy a full version of Polyboard… and he contacted Ness for an offer for Polyboard PP. I hope that will work.
In attached files you can see the pictures of the project finished.
Great thank to Mark and Ness for providing their help and guidance through my first project built under Polyboard.
Cheers,
Michal
DSC_0565.jpgImage Enlarger
DSC_0577.jpgImage Enlarger
DSC_0206.jpgImage Enlarger
April 28, 2015 - 2:21 pm
Hi Michal,
Pity you didn’t tell me about the 22mm nest, I must of run the last nest with a add panels to list instead of replace.
Sorry about the inconvenience, as you can see this is I’m not used to using Optinest with Polyboard. It should go better the next time round.
Here’s the 3D DXF.
all the best,
22
April 28, 2015 - 1:56 pm
hi Ness,
sorry for the late answer. The grooving problem and the edging problem were solved. Nevertheless I made by myself the nesting of the 22mm panel as the nesting you provided wasn’t correct. A lot of components in duple. Quite difficult to find out what is where, with 5 panels instead of 3…tiring computer work. Everything is now in machining as the contracting company needed it for monday, I hope there will be no further problem.
Can you send me the 3d dxf file please?
April 25, 2015 - 10:34 am
Hi Michel,
Thanks for pointing out these errors.
I seem to be having a Windows setup problem on my computer and some software settings are not being saved.
I have regenerated the files with your latest model, I have rechecked the Dxf files that now seem OK.
Can you double check to be sure?
Sorry about these errors.
Have a good week-end.
20
April 25, 2015 - 8:15 am
Thank you for nesting. The CNC machinist told me it should be ok. He will process it normally the next week.
Nevertheless, before cutting, there are several things I don’t understand in the files you sent. And I will have to modify them before cutting… after will be too late.
1.The 10 mm groove in the sides, top and bottom (for the back panel) stops at 53.59 mm from the edge of the panel. It should stop at 10, as the panels of the box are 18mm thick and the depth of the groove set in polyboard is 8mm. I’ve modified it manually but I’d like yo understand why.
2.There is some problem with the edging I suppose. In the files you sent, for example the 22mm board for facade elements (doors and drawer facades) the hole for the blum hinge should be at 23 mm from the edge. It sure is at 23 mm but the edge of 1mm was not deduced, so it will be at 24 mm after edging. Let’s take another example of the ‘caisson haut double porte’ : when we check the width of the double door (one door is cut at 523.75 x 2 = 1047.5, we put edges 4 x 1mm, we have 1051.5. The slacks shold be 1.5 on the left, 2.5 in the middle and 2.5 on the right = 6.5 mm: 1051.5 + 6.5=  1058mm. It should be 1054. So 4 mm more than needed. I found the same problem of 1 mm in the box parts (18mm panel). I can’t check the 15mm panel as I do not have the dxf file of the whole project.
In the 2 pdfs I send, you can see the detail. I also send the polyboard file as I modified the groove for back depth finally to 12 mm instead of 8 mm. If you can change that in the nesting, it would be perfect, otherwise it will stay on 8mm.
And the last: Would you mind sending the dxf file of the whole project as I like to see what I’m doing and keep the possibility of modifying it in cad program.
Thanks,
Michal
Currently Online: Jimmy Nilsson
Guest(s) 28
Zaheer Abbas: 88
Patrick Maylor: 63
Anthony Penn
almys111
Topics: 2107
Members: 262
