Michal from Poitiers, France |Page 2|Forum|WOOD DESIGNER
April 24, 2015 - 9:40 am
Hi Michel,
I had made a mistake in the grain direction of the first set of files, hope this set will be OK.
18
April 24, 2015 - 8:37 am
Thank you Ness,
I’ve send it to CNC company. I hope that it will be ok.
I’ve also noted that in the first version of nesting some pieces were missing (big doors in 22mm panel)…
Cheers,
Michal
April 23, 2015 - 5:37 pm
Hi again,
I have extended the sides and renested.
I have also printed a PDF labels file (-labels) that shows the edging on each part.
Hope this all works for your CNC guys.
16
April 23, 2015 - 2:07 pm
I see the modification. Ok for the plinth, it’s better with your solution, nevertheless these plinths will be added at the end of the project. I have made a piece of plinth longer needed.
For the extension of the sides of Caisson haut portes Vaissellier baubau: in fact the doors as well as upper drawer’s facades will be cut manually (with a plunge saw) at 45° angle. There are no handles on these… and I want the horizontal oak line be apparent between doors and drawer’s facades (that is why the front part of the bottom of this box is in massive oak.) The side is invisible on the right because the wooden oak top will hide it on 28 mm. If you want to see the detail you can look at the vaissellier-baubau3.skp file joined to my first post of this thread. You will also see why there is no plinth on the right side. Thank you anyway for your concern about this project.
I would like to send the file to my CNC machinist asap. Is it possible for you to change the detail of side and make a new nesting for 18mm panel, as it changes a bit.
I’ve also noted that edging doesn’t appear in the documents you sent. It would be nice for the machinist to now which edges have to be done. If it’s possible (and easy for you) I would be grateful. Otherwise I’ll mark them manually.
Thank you once again,
Michal
April 23, 2015 - 11:09 am
Hi again,
Sorry forgot to add it, here it is.
cheers,
14
April 23, 2015 - 10:32 am
Thanks for nesting. I would like to see in project the modifications you’ve made. Can you send it please.
April 23, 2015 - 10:26 am
Hello Michel,
Here are the nested parts files.
The cutting plans are in the materials sub-folders “xxxx-plc” .
I hope you don’t mind, but I’ve changed slightly your original design.
– I extended the sides of Caisson haut portes Vaissellier baubau to cover the bottom.
– I added a plinth to the end of Caisson bas biais double porte
– I extended the plinths of the Caisson Tiroir pass the sides to meet the wall and the plinth of the Caisson bas on the right.
Tell me if this is a problem and I’ll redo the files with your original project.
Note that this type of cutting list is good to nest if you machine the parts at the same time.
Otherwise, if the parts are just cut using a cnc or even a manual saw can be quicker and cheaper.
Just a thought….
April 21, 2015 - 2:16 pm
Hi Ness,
I’d like to precise some specifications for the nesting for the CNC router. My provider uses a 10mm drill router for panels thicknesses 10-15-18 mm and 18mm drill for panels thickness of 22mm.
All panels dimensions are 3100 x 1530 mm.
April 20, 2015 - 5:53 pm
Sorry, this copy is the right one…the difference is in the grain of the panel for the facades (doors and drawers). I forgot to activate the ‘grain’ option. Now it’s done.
April 20, 2015 - 5:15 pm
so I’m back with the project modified in some minor details. I’ve made a sub-method for tandem sliders, changed door and drivers slack…
I’d like to ask Ness to make a file with dxf and eventually a nesting for a Weeke CNC machine.
Michal
Guest(s) 19
Zaheer Abbas: 88
Patrick Maylor: 63
Anthony Penn
almys111
Topics: 2107
Members: 262
