Issues with non squared parts - Optinest and Board Size|Forum|WOOD DESIGNER
October 26, 2023 - 7:52 am
It seems that NC-hops do not manage multi-passing,
For now the documents you send with dxf coding don’t have specifique instruction to do this automatically,
Can there be a special code like for the type of drilling (Y15)?
You should contact your dealer or NC-Hops for information.
Marius Radu
Forum Posts: 55
October 25, 2023 - 3:28 pm
You have the file save as .hop
Thank you
  • sp_PlupMedia OptiNest_1-2.zip(637 b)
  • sp_PlupMedia Ouput-From_PB_Left-Side-2.zip(671 b)
October 25, 2023 - 3:06 pm
Please find attached a copy of the files from my previous reply to the post
Marius Radu
Forum Posts: 55
October 25, 2023 - 2:44 pm
Hi Alex.   I didn’t receive any files. you can send me one please
Thank you
October 25, 2023 - 1:52 pm
Can you load this files in Hops and send back .hops files or let me know if few pass are well generate
October 23, 2023 - 4:56 pm
Hi, as indicated in the previous answers, have you tested these files?
What are the results?
Marius Radu
Forum Posts: 55
October 23, 2023 - 3:14 pm
Unfortunately, I cannot upload the video, but this is a screenshot with the manual procedure I need to do on every piece.
  • sp_PlupMedia Mutipass-manual-.zip(283 KB)
Marius Radu
Forum Posts: 55
October 23, 2023 - 3:06 pm
Multipass
Marius Radu
Forum Posts: 55
October 23, 2023 - 2:59 pm
Hi Alex,
Thank you so much for your help. As I said in the video, after I did the changes, it looks good. I only need to test it into actual cutting it, but it shows that I should not have any problems with it.
Now, I would really need some help with the multipassing – now I have to go to each piece and manually change it to 16 (as I show in the video) and if I have multiple pieces, I need to manually do that to each one. Is there any way you can help me change that automatic to all the pieces? I would really appreciate that.
Thank you so much for your time and help,
Marius
October 23, 2023 - 8:36 am
Hi Marius,
Really nice project! We would be delighted to see the photos of the definitive project 😉
Marisu-Project.pngImage Enlarger
I you’ve found the problem! I’ve made this video to explain how to adjust the settings to solve your problem.
Regards, Alex
Guest(s) 37
Conor Devoy: 173
Jan Peter Oelen
ANDI MÖÖBEL - Tarmo
Topics: 2964
Members: 562
