Small parts are moving while machining|Forum|WOOD DESIGNER
Forum Posts: 2128
December 1, 2023 - 2:26 pm
Scanning the barcode, I understand, but the barcode doesn’t provide your drilling machine with the program or the drilling operations, or have I missed something?
The barcode only tells the CNC what program to call up (run).
Does PolyBoard need to send drilling instructions to your drilling machine?
If so, to my knowledge, for the Ganomat CNC, PolyBoard generates DXF files, which are loaded into the Ganomat “DXF Postprozessor” and send to Gannomat Editor
The DXF files are converted to *.gnax, and the generated barcode can be scanned by the CNC,
and the barcode to be scanned can be generated by PolyBoard
but I don’t know if this is the case for your drilling machine.
GannotMAT-edi.pngImage Enlarger
Marius Radu
Forum Posts: 55
December 1, 2023 - 1:37 pm
Alex said
Unfortunately this doesn’t help us,
Could you ask your technician if he is able to understand a DXF file which is the only format available by polyboard for this purpose?
and compatible working file on your drilling machine
Good day Alex,
I want to be able scan  the barcode not to import Dxf file, I don’t know if is the same thing or not. Please let me know
Forum Posts: 2128
November 30, 2023 - 7:46 am
Marius Radu
Forum Posts: 55
November 29, 2023 - 3:07 pm
Alex said
I’m not sure to understand,
Can you provide program can be read by your drilling machine?
Hi Alex. This is the answer from Gannomat technician.
Gannomat Index software based on MS Access platform.
Forum Posts: 2128
November 29, 2023 - 9:59 am
Marius Radu
Forum Posts: 55
November 28, 2023 - 2:22 pm
Marius Radu said
Alex said
Which files your machine required?
Hi already work with Gannomat CNC (From Ganner Editor), but working with DXF files,
Did you have DXF Postprozessor? this add-ons is to convert DXF to Gcode
Screenshot_20231128_091135.jpgImage Enlarger
Screenshot_20231128_091135-1.jpgImage Enlarger
Marius Radu
Forum Posts: 55
November 28, 2023 - 2:21 pm
Forum Posts: 2128
November 23, 2023 - 12:48 pm
Marius Radu
Forum Posts: 55
November 23, 2023 - 12:23 pm
Alex said
I understand,  but dxf never provided,
You need to look from NC-hops if there is option for program optimization,
To my knowledge all software proposed sorting operations options
Cheers,  Alex
Hi Alex. I fix the sorting tooling problem with Holzher.
What we need to integrate a dowel machine Gannomat Index 130?
Thank you so much
Forum Posts: 2128
November 19, 2023 - 12:53 pm
Cheers,  Alex
Guest(s) 41
everslyjoinery
Members: 537
