Small parts are moving while machining|Page 2|Forum|WOOD DESIGNER
Marius Radu
Forum Posts: 39
August 23, 2023
November 17, 2023 - 3:19 pm
Alex said
I’m glad it works for you, but I wonder if it doesn’t work only because it generates two entities, rather than two superposed layers with the same name.
fplp.pngImage Enlarger
I’d be curious to know if it wouldn’t work just as well with a First Pass and Last Pass configuration.
but don’t change if it work
Thanks for your feedback in all case
Hi Alex,
All works good except I encounter another problem:
When is doing the groove operation is moving the part. How do I change the operation order to put the grove, holes, and these operations before the outline.
Thank you,
Marius
Forum Posts: 1765
November 17, 2023 - 8:00 am
Marius Radu
Forum Posts: 39
August 23, 2023
November 15, 2023 - 3:05 pm
Marius Radu said
Alex said
Great new’s ! can you explain how you resolved multipass?
Good morning, when I will be at the shop I will make a picture because I’m not good to explain.  Is a way know to do multipass just for small parts?
Multipass.pngImage Enlarger
Forum Posts: 1765
November 14, 2023 - 2:23 pm
-You can do “Super PP” to sort parts, with filter from PB
sort-part.pngImage Enlarger
In this example, 2 export folders will be created,
the first PP export folder takes all the pieces with a height and width > 200mm
the second all the other pieces
Smal-part.pngImage Enlarger
export-test.pngImage Enlarger
but only works for rectangular parts
– Or you can sort sheet by manual priorities level from OptiNest
Hope that’s helpful
Marius Radu
Forum Posts: 39
August 23, 2023
November 14, 2023 - 12:55 pm
Forum Posts: 1765
November 13, 2023 - 7:55 pm
Marius Radu
Forum Posts: 39
August 23, 2023
November 13, 2023 - 5:57 pm
Alex said
-The first solution is duplicate PP with TT5 setting and second with TT3 Setting, to apply the tool to all the grooves
-The second is to used Custimozed Tools, for specified grooves in same cabinet / project
Hope that’s helpful
I did custom and is working, thank you so much for your help. Have a great week
Marius Radu
Forum Posts: 39
August 23, 2023
November 13, 2023 - 5:54 pm
Hope that’s helpful
Hi Alex, I fixed my self the problem with multipass, the problem was the Postprocessor.
Forum Posts: 1765
November 13, 2023 - 11:56 am
Hope that’s helpful
Marius Radu
Forum Posts: 39
August 23, 2023
November 13, 2023 - 11:26 am
Alex said
Sorry you are the first using NC-Hops en DXF import,
I tried to call Holzer for information, but they ignored my request because I wasn’t one of their clients,
They also told me that they needed the number of the machine and that there was a charge for technical service.
I invite you to contact them directly to ask “Is there a specific coding for multi-passage in the name of DXF layers?”
For groove in the PP layer name you should have something like “RT_TT<t=5>_L” or “RT_TT5_L”
5” number calling the tool in your librarie and just need to edit this number
Good morning, I will try to call them.
For the grove I have 1/4 and 3/4 in the same file, I can duplicate and create RT_TT5_L- RT_TT3_L in the same section or I need 2PP separately?
Guest(s) 20
Zaheer Abbas: 88
Patrick Maylor: 63
Chris Jackson
Anthony Penn
almys111
Topics: 2111
Members: 263
