Cabinet editing window failure|Forum|WOOD DESIGNER
March 23, 2024
Dear Alex,
We solved the problem.
We restored the windows to a past date. When we wanted to open the polyboard we had a message that the structure panel library did not work. We put a temporary library for structure and we open the polyboard. After that we rewrite the structure panel library and everything was ok.
So, there is a problem when the structure panel library breaks, the software does not show any messages. We tried to rewrites all the libraries but until we restored the windows these solution did not work.
We used your solution (send by email) and now everything is ok.
Thank you,
I have send mail without extra information!
Please let me know here!
This is from events viewer:
Faulting application name: Polyboard.exe, version: 7.10.21.1, time stamp: 0x65ba0ca8
Faulting module name: unknown, version: 0.0.0.0, time stamp: 0x00000000
Exception code: 0xc0000005
Fault offset: 0x1693ac68
Faulting process id: 0x38b8
Faulting application start time: 0x01da7e8e5ad765aa
Faulting application path: C:\Program Files (x86)\Boole & Partners\PolyBoard 7\Polyboard.exe
Faulting module path: unknown
Report Id: 4f22f7a8-df39-45fa-9341-f24634f3a235
Faulting package full name:
Faulting package-relative application ID:
Never uninstall your software!
I Need your project for analysis for dev team!
If, Can you let me know your PB version?
Perhaps your demo version is most recent, and you need to update or reinstall software following the same process
Look on top Left to see your version
More information for update here
And if you can work properly on demo mode may be issue already resolved
Thank you Alex,
The problem is not the project itself. I can open the same project in demo mode. The issue is happening for any project, also when I want to add a new cabinet. I think is linked to a missing resource in the window launching process.
The last chance is to reinstall the soft. For that I need some guidance for not losing any data (like projects, methods etc).
Thanks,
This is a rare typical crashing issue, unlike when windows recognises the blocked program when it recalculates
Can you send you Project for analysis,
