Cabinet File Request|Page 2|Forum|WOOD DESIGNER
Hi Justin,
Select the separator and go to the links in the property screen. Select the back . Type select recess and enter a recess value and it will reduce the depth of you separator. The best way is to select the sides of the cabinet and go to the property screen links and select the back. Add an overlap value. Do this for all sides and the back will be set more inside of the cabinet. If you then add a separator, it will join with the back.
As for your drawers you have to remove them and begin with new ones . Select the drawer type and qty and go to assembly . There you can go to the back reference and selecting from the back of the zone or the depth.
I see the back of your cabinet is not closing on the four sides. Is that what you want ?
Thank you. Also how do I make a vertical separator not go all the way to the back of the cabinet? I wanted the drawers in this cabinet to not go all the way to the back to accommodate plumbing. The vertical separator and the drawers need to only go in 15″ from the front. I couldn’t figure out how to do that in polyboard. I also wanted to figure out how to edit the face frame dimensions.
