It’s quite easy to set up your own libraries of hardware that you are using. It’s even better to set it up by yourself because you can modify it easily afterwards. I found the section
very useful to do that. The quick design library is a good starting point.
Michal
January 19, 2016 - 6:21 am
Is it possible to have our tooling links set by you. I can send some sample images of what we normally use and a polyboard file with the tooling applied.
