DXF export of Arc rather than segmented curves.|Forum|WOOD DESIGNER
MITC
Forum Posts: 60
November 22, 2022 - 9:58 am
That is much quicker.
November 22, 2022 - 9:55 am
We recommande to reduce “Smoothing” Option into menu Tools > Preferences to 2,
What it is often largely sufficient
SOpt.pngImage Enlarger
MITC
Forum Posts: 60
November 22, 2022 - 9:42 am
Just emailed it to you
November 22, 2022 - 9:40 am
Can you upload your cabinet?
MITC
Forum Posts: 60
November 22, 2022 - 9:23 am
I am just working on a fairly simple unit that has wine bottle storage at the bottom, done using circles on an inner tooling. It has made the whole model very slow to adjust anything. I have just timed it as 16 seconds to move the bottom shelf by 5mm.
Screenshot-2022-11-22-091823.jpgImage Enlarger
Is this because it has drawn lots and lots of little lines? Is there a way a can speed up the model by designing it differently?
These are my computer specs, incase you see anything on their which may be limiting performance.
Screenshot-2022-11-22-092152.jpgImage Enlarger
November 21, 2022 - 4:50 pm
Wherever possible, curved arcs are retained.
MITC
Forum Posts: 60
November 15, 2022 - 7:51 am
Is this something that is eventually going to be altered?
November 14, 2022 - 8:21 am
Yes, for the moment, only the single piece WITHOUT edges and without mortise and tenon have the advantage of a curved arch.
If you copy and paste the background structure onto the back, you will get an arc
MITC
Forum Posts: 60
November 10, 2022 - 3:41 pm
Here is a cabinet with a hole centrally located in the top and and meeting an edge on the bottom panel and the relevent exported DXFs
November 10, 2022 - 3:28 pm
Can you upload your cabinet for test
Guest(s) 36
Conor Devoy: 173
Jan Peter Oelen
ANDI MÖÖBEL - Tarmo
Topics: 2964
Members: 562
