DXF export of Arc rather than segmented curves.|Page 2|Forum|WOOD DESIGNER
MITC
Forum Posts: 60
October 3, 2022
November 9, 2022 - 1:01 pm
Using a groove instead of an inner tooling has fixed one of the issues, as the inner tooling path in no longer meeting the segmented “curve”.
Screenshot-2022-11-09-125605.jpgImage Enlarger
It still feels like Polyboard should be exporting an arc where they are perfect radius rather an a series of straight lines. But agree that Genio should be doing this better.
Forum Posts: 1970
November 9, 2022 - 12:27 pm
indeed, this is a concern I had with Genio R4
This is not a problem for other CAD software like VCarve because it performs the tool path on the tool axis,
the only solution with Genio is to use the “offset” function to create a parallel path, and then define that the tool passes on the axis,
The PolyBoard path is correct, so I invite you to contact SPAI Software to see if they are able to correct this bug
MITC
Forum Posts: 60
October 3, 2022
November 8, 2022 - 8:55 am
We are having an issue with the way that we are currently exporting our DXFs. If we use an inner tooling to create a circle in the center of a panel it then exports as an arc.
Screenshot-2022-11-08-083529.jpgImage Enlarger
But if we have the circle on the edge of a panel it is not exporting them as Arcs but lots of small segmented lines.
Screenshot-2022-11-08-083554.jpgImage Enlarger
Our CAM software is sometimes struggling with these lines and producing a toolpath that is not possible to machine, especially if the radius is similar to the diameter of the tool – I have been wanting to do this to include dog bones for CNC machine so when we export the file it is ready to cut. Rather than needing to apply these separately later.
Screenshot-2022-11-08-085058.jpgImage Enlarger
But we are also having a similar issue where when an inner tooling is meeting a segmented arc, such as in the top of the image below.
Screenshot-2022-11-08-085257.jpgImage Enlarger
Screenshot-2022-11-08-085341.jpgImage Enlarger
How do I get Polyboard to export any lines with a consistent radius to be an arc?
Most Users Ever Online: 365
Guest(s) 15
brendan kavanagh: 179
Tom Cleaver: 164
mark nichols: 162
Conor Devoy: 158
Zaheer Abbas: 132
Blake Simpson: 104
Patrick Maylor: 84
Tom Jackson: 83
EIlon Shperber
Alex Pop
Rick48
Hassan Sultan
Carmela Di Sorbo
Telmo Oliveira
Jesus Vergel
eduardo beiza
lucas Lucas Moreno
Topics: 2516
Members: 395
