February 8, 2022
Hi thanks for the help, that got my first stage done.
Now I need to make the doors so they can be resized but keeping the top/bottom rails and stiles to 90 mm and the a mid rail to 150mm.
here is an example of how we do our wardrobe doors made from a single piece of MDF.As we make them from one piece I don't think the "assembly" options will do what I need, so is there a way to create a "library structure" with the "inner tooling" to replicate these panels/recesses that will change size as I resize the door, keeping the above requirements for stiles and rails.
Matt
That's right, inner tooling for cabinet side,
https://wooddesigner.org/help-.....r-tooling/
and assembly for for doors
https://wooddesigner.org/help-.....-assembly/
NB: you can't create the top corner.
All the best, Alexandre
Matthew Murphy
February 8, 2022
February 8, 2022
Hi.
I am just trying to get to grips with the software as we speak and so for my first project I'm trying to replicate decretive filler panel below. The screen shot is as far as I have got. As well as that I would like to know how to make a one piece shaker door. (this is usually how we make them). if someone could point me in the direction of the correct tutorial that would be helpful.
