How to create a frame and panel assembly.
You can use bar or panel materials for the framework, you can add additional rails, apply shapes to the frame, change materials independently for each structural element and lots more.
You can also apply additional configurations from the structures menu one on top of the other.
This video shows one example of that, adding a second frame assembly inside the first.
