Setting reference point|Page 2|Forum|WOOD DESIGNER
Hi Grover,
Nesting is slower cutting panels than sawing. It’s main advantage is that it machines and cuts in the same operation without manual intervention. This enable the general manufacturing process to be around 30% faster that sawing and then sorting parts and putting them individually onto a CNC for machining.
This makes nesting much more efficient for small to medium volume production.
For high volumes with a lot of repeat tooling, it’s faster to saw and machine.
If you need perfectly cut panels when using sawing and machining production, you should use over sizing and a calibration cut on the cnc.
Hi Grover,
Please note that Optinest only produces cutting maps in DXF output so you have to tool path these in a CAM software.
This said it’s perfectly feasible to output only the outlines and have files without tooling. On the other hand I don’t see the advantage over cutting with a saw and using Opticut.
Why do you want to use Optinest to cut panels without machining?
Polyboard can not yet separate these 2 operations on its own for this particular request
It will work in two stages with different post-processor configurations.
1st step export the files in a first folder with the option to give previously “outline > ignore”
here to call “TPA_CN_OT_IGNR”
2nd steps
-Create a 2nd post-processor with the option “outline > export” by duplicating the post processor to keep the other configuration identical that we will call “TPA_CN_OT_EXP” for example
-Remove fixing links by selecting all cabinet in project mode and apply sub-method with NIL link
Or just apply this NIL sub-methodes link in single cabinet mode
-export to a new folder with the post processor creates previously “TPA_CN_OT_EXP”
But this solution don’t separate grooves,
Or using Opticut with Post-Pro export?!
I think that Ness can probably better inform you than me about this solution
Hope it’s help you
Hi Grover,
You want to have outline command without Tooling in a separte program?
or
First with it and second without?
Ness said
Hi Grover,I don’t know TPACAD either, but if the line of code is the outline of the panel you can delete it by setting the “Export whole outline” option the PP options to “Ignore”.
Would it be possible for Polyboard to separate the outline command?
Thanks,
Grover
