Torsion style floating shelves|Page 2|Forum|WOOD DESIGNER
OfflineHi Terry,
This is quite easy to set up using just one panel.
Take a cab and get rid of everything except one panel.
Go to edit structure and use the thickness split and make a three layer panel.
then add a framed assembly to the mid panel and change the materials of the others as necessary.
Have a look at this video:
https://wooddesigner.org/membe…..ch-panels/
Hi Ness
Is it possible to create a torsion style frame out of par softwood and then to be able to drag it into an alcove or flatwall to then
add 18mm mdf to top and 6mm to bottom to create a floating shelf and for all components to show up in cutlists.
Or is there another way to go about this. Did think of using bar material to set up battening but not quite sure.
Pic attached of basic frame without adding the outer skin of the sandwich.![]()
Terry
