Outside Stairs|Page 2|Forum|WOOD DESIGNER
OfflineHi Willi,
As agreed here is model with the landing at 2150 from step nosing to the outer face of the 90×90 posts.
I’ve also changed the first flight width so that you have 1000 to the outer face of left posts.
Please check the dxf file in Draftsight and add any dimensions that need changing.
OfflineHi Willi,
I’m not sure what you mean by “first upper step” or fist over step on a couter bearing”.
To make sure I understand your project, can you send me a drawing or dimensioned sketch of the stair and it’s supports.
I’ll also need to have the list of thicknesses and sections you’ll be using for the different parts.
For me to look in detail at your project and send you the files you’ll also need to buy our StairFile service from this page:
As we just discussed here is the example I did generate with the stair designer.
What I would need is the production data, means all measurements. I don’t need any schablones etc.
Also there will be some add on I would like to discuss with you.
The first upper step should be 2150mm and should also 500mm wider than the stairs which are 1000mm.
The whole construction should be on top of the 4 pillers and on the fist over step on a counter bearing.
Everything should be out of steel.
Willi
