Stair design output request|Page 2|Forum|WOOD DESIGNER
Hi Harald,
I will check your stair today. You mention that you need templates? So you refer to our 1/1 scale pdf’s? If so this is a paying service. Stairfile is for free but does not contain the templates
In case you need our 1/1 scale pdf templates here is the link for the payment. It is to be found on the page bottom.
Mihel
HI Michel
What is the default that you are referring to?
Penetration parameters, please define not good vs good
Using imperial measurements
I’m using 1 3/4″ stringers with 1″ thick steps.. route out for steps and risers is 3/4″
Steps will overhand riser 1″
Using wedges under each step and riser
This stair is for my self so I can adjust as necessary.
Can you make corrections and give me templet for steps and stringers?
Thank you
Harald
I am using Imperial measurement.
My stringers are actually 1 3/4″ thick, I would route out about 3/4″ for risers and steps
I usually give about 1″ for step overhang over front of riser
I have not had a chance to look at drawing again but will check tonight.
I also corrected this message as there were several mistakes
thanks for your patience.
Harald
Hi Harald,
Have you checked the components of your stair? You used a default in the software which is not a common stair setup.
also, some penetration parameters are not good. Units are in mm? Are you not using imperial? We need you to recheck your design.
Please check and also check your render in 3D.
I’m uploading here a StairFile request from one of our subscribers.
Harald, please can you add a post and confirm you’re happy with your design and would like the manufacturing output.
My colleague will then process your design and upload the files here.
Thank you
