Stairdesigner 7|Page 2|Forum|WOOD DESIGNER
Hi Hasse
somehow you made some changes that created this . Some cutstringers were deleted. When I added back the cutstring it was all connected again.
You can change the newel size in the properties . Select the newel and in the properties go to “Section”. You can choose between square, rectangular or circular. Also the height can be corrected in the section top and base height
here is the result
February 18, 2014
Hi again
well it seems to not fit.
I have problems with newel post 5 and 6 or it is problem with the inner handrails.
It iooks like handrails are shorter beacuse the newel posts no 5,6 are smaler than 1,2.
Can it be like that?
Cant I have difrent size of posts?
Post nr 1,2,7,8 are 80×80 mm rest is 60×60.
I have try to change on newel references tohandrail and to automatic but its not helping me.
I hav also manual take the topp hihger then 50 mm over handrail, but probebly that is beacuse they not conecting.
If you can show me like Ness did erlier with links in this topic.
Thank you in advance
Hi Hasse
in the properties of the newels I changed the references axis to handrail. This is centering the newels on the handrail and then it is all connected . See attached
Hi Hasse,
If you are in StairDesigner 6 use the “position / ref.point:
in StairDesigner 7, in the plan view, right click and choose “add newel post”.
When asked to “click position where to add”, click the string where you want the post:
StairDesigner will add the post and you can set it’s parameters.
In the 3D view delete the extra hand rail and stings:
The post position can now be adjusted using the “position” parameter:
Hope this is helpful,
