Things are not square|Page 3|Forum|WOOD DESIGNER
I hope this is what you need. If not, let me know.
Here is the list of dimensions. F is the basement and C is the top.![]()
I did three levels of measurements because it is a very old house and things are not right. If you only use the middle one, I can make it work anyway, because I will not be using CAD. I’ll take the templates and cut to fit.
OfflineHi Scott,
Yes, you can add an angle to a flight or even more precise, draw the situation in cad after measuring properly to get the angles. SD can be used with x-y coordinates and so follow practically any kind of irregular shape.
If you are not able to do it provide me with a plan with all the needed measurements so that I can draw it in cad. No angle values, only measurements.
Currently Online: Tom Jackson
Guest(s) 71
Tom Jackson: 134
Timothy Bennett
Members: 536
© Simple:Press —
