Hi Jon,
The problem may come from 2 things, either the PDF is not at the right scale or the printer has not printed it at the right scale.
Make sure that when you print from AutoCad / Draftsight the fit to paper option is not ticked and that the scale is set to 1mm = 1mm :
Print to a PDF printer like PDF Creator.
Once the pdf file printed, to make sure the print is at the right scale, you can verify the size using PDF software like Foxit that can measure a line.
If the scale of the pdf file is OK the problem comes from your professional printer who is setting his printer to fit to paper (or some other scale) and not to 1 to 1.
October 25, 2015
Hi again
I have tryed to use Autocad to make PDFs i 1:1 scale, and then I had a professional printer to print step 12, just to see if I made it right. When I measure the length of the step in Autocad, it should be 748 mm, but when I measure the print, it is 743 mm. When I try to use DraftSight, it looks like getting the sea problem. Do you have a description or a tutorial that I can follow to make the prints right?
Hi Jon,
The pdf are only scale drawings that you will not be able to print full sze.
Full size pdf's are only available in our paid StairFile service.
To print your parts full size you have to load them into a CAD program AutoCad or you can use our free CAD Draftsight (see the software download page here:
https://wooddesigner.org/membe.....raftsight/
I can send you the full size PDF's but will have to charge you a fee of £95 (StairFile Pro) as this is not in our free service and does require extra work.
edit: sorry, I included the wrong price for StairFile Pro earlier...it's correct now
October 25, 2015
Hi
Thank you for the files. I gave the PDF to a proffesional printer, but they struggeled to make prints 1:1. I can see that many of the files is AutoCad-files. I don't have AutoCad. How can I make PDF's in 1:1 from the CAD-files so it will be easy to print all the parts 1:1? Can you do it for me?
Hi Jon,
Sorry to reply so late but I have been away on a trade fair in Paris fro the last week.
Here are the documents to build your stair.
I have slightly adjusted the position of the steps and strings to make housings in the newels easier.
Hope the build goes well.
October 25, 2015
October 25, 2015
Hello Jon,
Yes you are perfectly right with the landing step removed the wall to last nosing is 1750.
This means that in the project you have the left top post is up against the landing joist whereas the right post is sitting on the landing.
October 25, 2015
Hi
Thank you. Attached you find a simple drawing from the top of my stair. As you se, the stairwell-room is 175 cm long. Is it right to measure the lenght from the nose of the last step and over to the wall at the oposite side? I have tryed to ilustratte this With the drawing and the adjustments in my sds-Project.
Hi Jon,
To remove the last step set Landing Step to "0"
The stair is now calculated up to the nosing of the last step.
This means in your case that the post is resting on the first floor, or notched leaving only a small amount in front of the joist.
Note also that the last riser is now in the landing joist so has to be ignored.
I always advise using a landing step if at all possible.
If you leave the stair without a last step you have to adjust the position of the last post according to how you want to set up the transition with the first floor.
October 25, 2015
I like your changes, but maybe 20 cm riser hight is a bit to high, I changed to 13 steps. I also want to change step 13 (the half step on the top), but I dont know how to do it in the program. I don't want the half step om the top, but make step 12 to be the first step from the top. That means that the 2nd floor (240cm over 1st floor) will replace step 13. Is that possible to do?
Hello Jon,
No problem to send you your project files.
However, before I process your project I want you to know that there are a quite a few details that will make your project complicated to build.
I have tweaked your stair and set it up to have a coherent detailing.
I suggest that you edit my model to get the design that suits you.
Have a look and tell me what you think.
October 25, 2015
Attached, you will find my first design for my stair. Very fun to use the software. I was told that I should post my project here to get cutting list and everything I need to start building. I also want some advices for how I can manage to get all curves and angles right when I'm coming to export it from a piece of paper to the wood.
