How to adjust all steps and risers of your stair at the same time. You can add/remove risers, change material, thickness and the step nosing to riser distance. You can also fine tune the step to riser assembly details, including editing the riser into step groove dimensions, sitting the riser behind or on top of the preceeding step, and extending that preceeding step behind the riser.
- Home
- Knowledge Base
- StairDesigner tutorials
- Part properties
- General step parameters
