Wedging is a specialist link parameter feature that extends the step and riser housing to the edge of the stringboard at a pre-defined angle.
Normally you would apply this to the step but you can add it to the risers as well if required.
Wedges are used extensively in some countries to create a very strong joint and are particularly helpful for assembly of a stair on site that sits between two walls.
