- Home
- Knowledge Base
- StairDesigner tutorials
- Part properties
Part properties
A look at each of the major components of a stair project - steps, stringboards, handrails and newel posts - and how to apply and modify their parameters. It's possible to edit all instances of a component at the same time, or to select an individual step, stringboard etc and adjust that independently of all the others.
The control and flexibility that's possible makes it very quick to optimise your design for aesthetics, safety and ease of manufacture.
General step parameters
How to adjust all steps and risers of your stair at the same time. You can add/remove risers, change material,...
Individual step parameters
How to select and individual step and modify its parameters in isolation, with a similar set of options to the...
General stringboard parameters
How to modify the stringboards of your stair. Options include changing the material, thickness and width of your stringers, and...
Individual stringboard parameters
As well as modifying all strings at once, you can select each individual stringboard and edit it separately. You have...
Handrail parameters
How to add and modify handrails in StairDesigner. Handrails can be curved (following the step nosings), straight or constructed in...
Newel post parameters
How to add and modify newel posts. As usual, it is easy to change the material of one or all...
Link parameters: step/stringboard
Link parameters describe the way the parts are assembled to each other. Here we look at the assembly between steps...
Link parameters: step/newel
How to adjust the penetration of the steps and risers in the newel posts. This can be adjusted for all...
Link parameters: newel/stringboard
How to modify the joint between a newel post and stringboard. As usual with the link parameters, you can modify...
Link parameters: newel/handrail
A look at the handrail into newel post assembly options in StairDesigner. You can edit all newel post to handrail...
Link parameters: between stringboards
How to adjust the assembly details of two adjacent stringboards using the link parameters section in the properties menu. As...
Link parameters: banisters
The assembly between the banisters and the handrail and also between the banisters and the stringboard can be adjusted to...
Link parameters: wedging
Wedging is a specialist link parameter feature that extends the step and riser housing to the edge of the stringboard...
