How to select and individual step and modify its parameters in isolation, with a similar set of options to the General Step Parameters. Editing a single step is particularly useful in certain cases, for example adding a riser to the last step to hide a joist. The Step Type parameter is also covered here, including the difference between a winding and a straight step.
- Home
- Knowledge Base
- StairDesigner tutorials
- Part properties
- Individual step parameters
