As well as modifying all strings at once, you can select each individual stringboard and edit it separately. You have a similar set of options as are available within the general stringboard parameters, such as adjusting the material, thickness and so on.
This video focuses on the Type parameter, allowing you to change between curved and straight strings, and a combination of the two. This feature, used in conjunction with adjustments to the string angle, width and string to nosing offset, offers a very good way to edit and optimise each string quickly and efficiently.
