Link parameters describe the way the parts are assembled to each other. Here we look at the assembly between steps and strings, in other words how the steps and risers are housed within the stringboards. You can adjust the depth of the groove within the strings, independently modify steps and risers, even create step cut outs to create a tenon joint.
As normal in StairDesigner’s parameters, you can modify the stair globally or select individual steps and strings and edit each separately.
