How to add and modify newel posts. As usual, it is easy to change the material of one or all the posts at the same time. You can adjust the shape of the section, offset along the stringer or laterally, and adjust the height of the top and bottom positions of the post in relation to the stair itself or to the floor.
Newel post section shapes can be defined as follows:
- Square
- Rectangular
- Circular
- Diamond tip (corner newel posts only)
