scm n100|Forum|WOOD DESIGNER
scm n100
Forum Posts: 1959
February 26, 2024 - 9:37 am
Two ways ,
The first and simplest is to ungroup the parts in order to generate a single file for each part.
ungrp-1.pngImage Enlarger
The second is to use the *.CSV PostPro report file to import parts lists, which manage the quantities of grain, material, etc… but required to work with PGMX converter
More information from help available into your computer with Maestro (Maestro editor.pdf)
maestro-csv.pngImage Enlarger
and can be formatted from PP option,
csv-formmating-1.pngImage Enlarger
Andy Brown
Forum Posts: 17
January 18, 2024
February 23, 2024 - 5:55 pm
Hi Alex
Also is there anyway to convert the number of parts directly to maestro? ie if you have a draw side and need 4 of them it nests 4 automatically instead of me having to change the quantity’s of each individual part?
Forum Posts: 1959
February 23, 2024 - 9:27 am
Looking your PP setup can you try to set “export the whole Outline” to “No”
pp-maestro.pngImage Enlarger
The SCM pp are very modular, what works on a machine will not necessarily work identically on another machine of the same models, which makes all their complexity.
We have another user with N100 who can only work with DXF PP export, OptiNest and Vcarve then work with XXL files….
Andy Brown
Forum Posts: 17
January 18, 2024
February 22, 2024 - 5:32 pm
Hi Alex
So how would i go about removing the milling from polyboard and letting maestro do it?
Forum Posts: 1959
February 22, 2024 - 10:20 am
No, this solution is only for drilling,
Andy Brown
Forum Posts: 17
January 18, 2024
February 22, 2024 - 5:58 am
Hi Alex
The -1 has worked, but in terms of the milling if remove the tool from polyboard will it then not translate so i can do the automatic cut on maestro? just so i can check the optimization and see if its better?
Forum Posts: 1959
February 21, 2024 - 12:29 pm
PolyBoard Export files piece by piece, unless Maetsro’s optimiser changes the order, in which case there is no reason to move from one piece to another without finishing the job.
The customer mention on the post linked use Maestro and XCS without any troubles,
For drilling can you try to set it to “-1” Automatic please see video below
the tool number can’t be empty and as default set to 101 tool
Andy Brown
Forum Posts: 17
January 18, 2024
February 20, 2024 - 6:23 am
Hi Sorry forgot to say that it also has an error with selecting the boring unit head for the drilling, i have to change every drill hole to automatic otherwise it wont run and it takes a while
Andy Brown
Forum Posts: 17
January 18, 2024
February 19, 2024 - 2:35 pm
hi Alex
I have tried different types of optimization and even spoke to scm but they said because it coming from another software and the milling is already attach it wont work out the best way to optimize apparently ill attach a few photos.
so on the photos you can see that it will jump from one board to another and only do one hole on each panel, and it does this throughout even though i have tried different types of optimizations
Forum Posts: 1959
February 19, 2024 - 2:17 pm
OK,
For drilling you can read this post!
>https://wooddesigner.org/forum…..or-drills/
For Program in can do anything from PB, because output is part to Part,
Maestro has a programme optimiser, but I can’t remember the position and name of the options available.
But I’m sure there’s at least one optimiser for each type of machining (sequential) and another that optimises the machine path.
Most Users Ever Online: 365
Guest(s) 20
brendan kavanagh: 165
Tom Cleaver: 164
mark nichols: 162
Conor Devoy: 158
Zaheer Abbas: 132
Blake Simpson: 104
Tom Jackson: 83
Patrick Maylor: 81
Miryahya Khameneh
mathew moule
Christian Lopardo
Romerworld
Evaldas Gudenas
Petr Břichnáč
Ar Te
Ilie Mihail
GERARDO MARMOLEJO
Salman Bukhari
Topics: 2478
Members: 379
