Flared / Hours glass Stairs... HELP !!|Page 6|Forum|WOOD DESIGNER
February 26, 2015 - 7:16 am
Hi Kevin,
No problem to draw you these stairs.
If you just want the design and plans drawn to build, you can use our Stair Plan service here:
https://wooddesigner.org/stair…..n-service/
Do you want us to build them for you too?
We could also find you a supplier to build and eventually install them.
February 25, 2015 - 3:16 pm
I Would like:
Natural Light Oak Stairs
that I call hour glass stairs the flare at the top and at the bottom but other wise straight up and down
e.g Dimensions at 1st Floor level the width of the stairs would be 1200mm wide
each step would then reduce down to the middle step that would be 1000mm wide
the remaining steps would then extend out to the bottom step and ground level that is 1500mm wide
stairs will be carpeted so the steps / treads can be a utility product rather than natural oak
this is going into a brand new Georgian design property
I have added some pictures none of the show exactly what I am after however its does show the flared design nicely
(Height from ground level to first floor is 2565mm)
is this something you could do Ness ??
Best Regards
Kevin
min1.jpgImage Enlarger
this one is pretty much on the money !!
DSCN0013.jpgImage Enlarger
 Flared-Stair-1.jpgImage Enlarger
 flared-stairs.jpgImage Enlarger
 IMGP0588.jpgImage Enlarger
 oak_flair3.jpgImage Enlarger
Currently Online: Zeljko Blascak
Guest(s) 10
Zaheer Abbas: 88
Patrick Maylor: 63
Chris Jackson
Anthony Penn
almys111
Topics: 2111
Members: 263
