exporting design from polyboard to a 6 sided drilling machine|Page 2|Forum|WOOD DESIGNER
khalid khalaf
Forum Posts: 19
March 11, 2024
March 12, 2024 - 11:16 am
khalid khalaf said
Alex said
don’t worried, we should end up finding a solution
May you try to open files instead of import?! or annoter similar options.
I Can’t find information about PCDrill32 from internet….embarassed
The first point you need to look is the config file of DXF import
cfg.pngImage Enlarger
Did you CNC have internet access ? I can look by TeamViewer 13 Quick Support if I find something
i got this from the drilling machine pc
just remove .txt from the end
khalid khalaf
Forum Posts: 19
March 11, 2024
March 12, 2024 - 11:15 am
Forum Posts: 2037
March 12, 2024 - 10:51 am
khalid khalaf
Forum Posts: 19
March 11, 2024
March 12, 2024 - 10:10 am
Alex said
this files is un XLM data files can’t be export by PolyBoard ,
and can’t work from this files,
I need to have working DXF or MPR files to make PolyBoard Specific PostPro to read them into your software,
You may be able to ask your reseller for sample files in MPR or/and DXF?
Cheersn Alex
i will do that tomoro morning
sorry for any inconvenience i may have caused, this thing is eating away my sanity, i am usually good in figuring out stuff like this
khalid khalaf
Forum Posts: 19
March 11, 2024
March 12, 2024 - 9:52 am
Alex said
Sorry I can’t help you for MPR, you should look if you have import option or if you can change format when import file,
did the PDF for Syntenc DXF is on your machine or find to internet?
May you have PDF help from your software?
PDF for Syntenc DXF was provided to the company with the drilling machine by the installer from Naxing
Forum Posts: 2037
Cheersn Alex
khalid khalaf
Forum Posts: 19
March 11, 2024
March 12, 2024 - 8:55 am
the  TEST-PANEL.scx did not help ?
Forum Posts: 2037
March 12, 2024 - 7:42 am
khalid khalaf
Forum Posts: 19
March 11, 2024
March 12, 2024 - 6:31 am
Alex said
My setup is based on following info describe below by PDF
DXF-layer.pngImage Enlarger
If you open dxf from classic CAD you can see all is respected,
layerinfo.pngImage Enlarger
Can you check your config file to look if default naming are used?
Unfortunately I’m not able to download the test file.
test-dxf.pngImage Enlarger
Else you can try MPR format into to attached ZIP
Cheers Alex
i too was not able to download the test file
would you kindly explain how to try MPR format?
thnx
Forum Posts: 2037
March 11, 2024 - 10:29 am
Cheers Alex
Most Users Ever Online: 365
Currently Online: dermotcoll, Graeme Collins
Guest(s) 24
brendan kavanagh: 190
mark nichols: 162
Conor Devoy: 158
Zaheer Abbas: 140
Blake Simpson: 104
Patrick Maylor: 98
Tom Jackson: 89
Simran simran
Edin Pineda
Sabrina.loitiere
Chang Jia Jie
Marius Pauliuc
BRANIMIR Georgiev
Jorge Tellez
Katie
JORGE DUTAN
saintbilly
Topics: 2582
Members: 417
